Topic "Unable to import an exported ini file"
ferrari2k
the documentation here is incorrect, as the mentioned menu point "Tools > Import/Restore configuration" does not exist on the login dialog, as shown in the screenshot here.
Please show how to import the exported ini and update your documentation so it represents the current version of the program Wink
Thanks in advance!
My version of WinSCP is: 4.3.5
Best regards
You need to upgrade to the latest version of WinSCP. You version of WinSCP does not have explicit import command (though you can still copy the INI file to the .exe file folder).
