Topic ".NET: Mask to get today's file using ListDirectory method"
Suresh
I am currently developing a VB.NET application and I wanted to list out all txt file today’s file available in SFTP folder. The application uses Winscp.dll (version 5.0.6.0).
I am passing *.txt along with the sftp path to ListDirectory method
Example: /Test/*.txt
It downloads all files available in the /Test/ folder with .txt extension, then I am looping through each file and checking the file date time and filtering today’s file.
I found there is a Mask feature where we can specify the date time.
Ref: http://winscp.net/eng/docs/file_mask
>yyyy-mm-dd[ hh:mm[:ss]]
Matches files modified the last time after the date or time (i.e. “newer than”).
>2012-01-01,>2012-02-29 08:47
But when I pass the File Mask to List Directory method, it is not supported.
/Test/*.txt>2014-02-21
I believe I am missing some points here, please help.
Code Snippet
Imports WinSCP
Try
   With sessionOptions
        .Protocol = Protocol.Sftp
        .HostName = HostName
        .PortNumber = PortNumber
        .UserName = UserName
        .Password = Password
        .SshHostKey = SSHHostKey
    End With
   Using session As Session = New Session
      session.Open(sessionOptions)
      Dim directory As RemoteDirectoryInfo = session.ListDirectory("/Test/*.txt>2014-02-21")
   End Using
Catch e As Exception
     WriteInLogFile("Error : " & e.Message.ToString)
End Try
WinSCP
WinSCP 5.0.6 (Build 2074)
Kindly note that I don’t want to download the file.
Suresh
That's correct, the Session.ListDirectory does not support file masks. You need to filter resulting file list yourself.
Suresh
Thank you for your response.
I have added an example:
http://winscp.net/eng/docs/library_example_listing_files_matching_wildcard
Though it's for PowerShell only.
Suresh
Thank you for your reply. As I informed I am looping through all files and filtering.
Regards
Suresh
