Topic "FTPS Explicit TLS .NET Libarary"
bgolfer66
Edit: Sorry, user error. I was not setting the SSLHostCertificateFingerPrint before connecting.
Sorry for the rogue posting.
John
Quote:
Hello, I'm having an issue connecting to a FTPS site using Explicit TLS encryption through the .Net Library through Powershell.
This is a new problem and first time I've tried using FTPS with Explicit TLS. WHen I use the GUI interface, I am able to connect.
When I go through the powershell code, I get an unable to connect exception.
Here is my code:
    $winSCPathDLL = $global:appSettings["WinSCPDLL"]
    $winSCPDLLPath = $winSCPath + $winSCPathDLL
    [Reflection.Assembly]::LoadFrom($winSCPDLLPATH) #| Out-Null
   # Setup session options
   $sessionOptions.Protocol = [WinSCP.Protocol]::ftp
    $sessionOptions.FtpMode = [WinSCP.FtpMode]::passive
    $sessionOptions.FtpSecure = [WinSCP.FtpSecure]::explicittls
   $sessionOptions.HostName = $global:appSettings["FTPHost"]
   $sessionOptions.PortNumber = $global:appSettings["FTPPortNumber"]
   $sessionOptions.UserName = $global:appSettings["FTPUser"]
   $sessionOptions.Password = $global:appSettings["FTPPassword"]
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
   $session.Open($sessionOptions)  #<<< Exception throw here
When I load the assembly, I get this:
GAC Version Location
False v2.0.50727 D:\ServiceOrders\Script\WinSCP\WinSCPnet.dll
I downloaded the latest .Net DLL today, so I have version 5.5.1.0
The exception details I can get to :
Connection failed.
At D:\Script.ps1:167 char:3
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], SessionRemoteException
+ FullyQualifiedErrorId : SessionRemoteException
I'm sure I must be missing something, but I am at a loss for finding it.
Thank you for the help.
John
Silku
John, have you got any solution for the above ? I am getting same problem.
Thanks.
bgolfer66
Thanks.
I Did. The issue I was having was in setting the SslHostCertificateFingerprint print.
Here is my Powershell code for connecting.
I got the value for the finger print by connecting to the site using the gui,going to the commands menu and choosing "Server/Protocol info"
Hope this helps.
    # Load WinSCP .NET assembly
    # Use "winscp.dll" for the releases before the latest beta version.
    $winSCPath = $global:appSettings["WinSCPath"]
    $sessionOptions.SslHostCertificateFingerprint = $global:appSettings["FTPFingerPrintKey"]
   try
      # Connect
           $yesterday = (Get-Date).AddDays($yesterdayValue).ToString('yyyyMMdd')
           # List of remote folders to check
           $remoteFolders = $global:appSettings["RemotePaths"]
           foreach ($remoteFolder in $remoteFolders.Split(","))
              $remotePath = "/" + $remoteFolder.Trim() + "/*" + $yesterday + "*"
              $localFolder = $localPath + $remoteFolder + "\"
              $TransferResults = $session.GetFiles($remotePath, $localFolder, $false, $transferOptions)
              try
                $TransferResults.Check()
              catch [Exception]
                    $emailBody += "Error Downloading " + $remotePath + ":" + $_.Exception.Message
        $session.Dispose()
[/code]
Silku
Jon Thanks...but after this when I changed this similar like this.
It says authentication failed Sad(( any idea....?
Your help is much much appreciated....eagerly waiting...
Silku
Don't know if this allows to authenticate, I copied it from server/protocol info only.
bgolfer66
I would need to see your code.
Silku
Thanks John.
Here it is : I have given write host trap from where it is causing....
Now it is saying "The requested operation requires elevation"...Sad(
try
write-host "Begin..............." -foregroundcolor yellow;
[Reflection.Assembly]::LoadFrom("C:\Program Files (x86)\WinSCP\WinSCPnet.dll")
write-host "After assembly...." -foregroundcolor yellow;
write-host "After Open WinSCP.SessionOptions...." -foregroundcolor yellow;
write-host "After Open WinSCP.prtocol...." -foregroundcolor yellow;
write-host "After Open WinSCP.ftpmode...." -foregroundcolor yellow;
$sessionOptions.PortNumber = "22"
$sessionOptions.HostName = "ftp.zzzz.com"
$sessionOptions.UserName = "zzzz"
$sessionOptions.Password = "*****"
write-host "After password...." -foregroundcolor yellow;
$sessionOptions.SslHostCertificateFingerprint = "xx:e3:74:c5:a7:e3:0f:5b:d3:77:6e:bd:58:19:a6:2c:33:e8:fa:ec"
write-host "After Open SslHostCertificateFingerprint ...." -foregroundcolor yellow;
write-host "After new session ...." -foregroundcolor yellow;
try
# Connect
write-host "Before Opening ...." -foregroundcolor yellow;
write-host "After Open Session...." -foregroundcolor yellow;
$localPath = "E:\Apps\"
$remotePath = "/SFTPPourshinsDownload"
$file = "CS_20140703_050427.csv"
# Format timestamp
$stamp = $(Get-Date -f "yyyyMMddHHmmss")
# Download the file and throw on any error
$session.GetFiles(
($remotePath + $file),
($localPath + $stamp + "." + $file)).Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message -foregroundcolor green
#exit 1
$host.enternestedprompt()
write-host "To see the output........." -foregroundcolor yellow;
pause
What line of cause is causing this error? It's definitely not a message from WinSCP.
Silku
After this line
Authentication failed but I can connect through GUI base...
bgolfer66
Nothing looks out of the ordinary to me. I am able to substitute my connection credentials into your code and connect to my server.
whatever is happening is outside my area of expertise. Hopefully a site admin can help you.
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
Thanks John. Waiting to hear from him.
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
bgolfer66
You may want to check that you should be using FTP Secure and not SFTP
and if it is FTPS, is TLS the proper security?
Silku wrote:
Thanks John.
try
try
# Connect
# Format timestamp
$session.GetFiles(
finally
$session.Dispose()
exit 0
catch [Exception]
#exit 1
pause
Please start a new topic and attach a full session log file showing the problem (using the latest version of WinSCP).
Silku
Although through GUI, it is creating the session log.
What I am missing..
$session.DebugLogPath = $WinSCPDebugLogFile
$session.SessionLogPath = $WinSCPSessionLogFile
$session.XMLLogPath = $WinSCPXMLLogFile
Silku
2014-07-11 10:47:42.098 331 Password required for
> 2014-07-11 10:47:42.098 PASS ********
< 2014-07-11 10:47:42.119 530 User cannot log in.
. 2014-07-11 10:47:42.119 Connection failed.
. 2014-07-11 10:47:42.120 Password prompt (last login attempt failed)
I do not know how to help you. Are you able to connect from GUI? It seems like your username/password is wrong or the account is disabled.
Silku
Yes, Martin, with same configuration I can able to connect with GUI...
Silku
Thank you all . This is resolved.... Mr. Green
Sriram
Dear All,
Actually i m using secure ftp, I am using winscp to push the file to sftp, but in session.open i am getting error. i gave ftpurl, hostname, username and password, but i never give sshostFingerprintkey, instead of this i gave sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true; .. But not resolved. how i achive that.
Sriram wrote:
Dear All,
Am using Asp.net with C# along with WINSCP
Sriram wrote:
i am getting error.
Would you mind telling us, what error is that?
Even better, start a new topic and attach a full session log file showing the problem (using the latest version of WinSCP).
