Topic "Most recent file selection with WinSCP command line"
sivaramanm
How do i achieve this using winscp command line automation commands?
http://winscp.net/eng/docs/script_download_most_recent_file
Your duplicate question on stackoverflow:
http://stackoverflow.com/questions/22388746/winscp-select-most-recent-file
Quote:
You cannot do this on command-line only. If it was possible, the solution in WinSCP documentation would show it instead of the use of wrapper script.
The closest you can get with command-line only is using file mask with time constraint. For example, if you know that one file per day is added only, you can use *>1D mask to select files (one file actually) created within the last 24 hours.
Andreb
Hi All... Please please can somebody help me - I'm struggling my ╤╚♦ off Smile
I have files - 6 of them sitting on a remote site, every day a new is placed, I need to download only the newest one, the file name changes every day to I'm aiming at using the "latest date" - needless to say my scripting knowledge is void - I've tied using the >1d - WinSCP does all sorts of weird things and gives me a file called %3C1d - what the hell is that??
my command currently reads "get //ftp05155/FTP*.* <1d"
Please can someby please assist with the correct syntax that would allow me to automate the download of the latest file between 6 others from the SFTP please - connectivity is working, just the download seems to be problematic....
thanks a Huge load for your efforts, much appreciated!
Andre
There should be NO space between *.* and the time constraint + It should be >, not <.
Are you sure the path should start with two slashes?
Btw, it would be nice, if you accept the answer you got on stackoverflow.com.
SLee
I know its really old post , but I had similar requirement, and what worked for me is : get /out/abc.z*>16h %LOCAL_PATH% where abc.zip was my exact file name in out folder. It got me only abc.zip.
