Topic "Change user in WinSCP"
one2connect
I am using WinSCP for years and enjoy the windows look, edit the file from within WinSCP.
Recently we have moved to CAUTH authentication. Sys Admins have change the privileges which means I have to log in myself, I can view the files but to edit I need to launch putty and sudo <OtherUser>. OtherUser is the owner of the files.
Steps I do if I need to edit files.
>I log in as myusername/mypassword in WinSCP. I can view files but not edit them.
>To edits from within WinSCP I "Open session putty" as myusername.
>My Putty command line I have to issue the following command "sudo -u <OtherUser> -i". Enter "mypassword" and I am free to edit any files.
How I can login directly or change user to "OtherUser" within WinSCP?
I really want to avoid "vi" editor to edit files.
I'm not really sure that there's any solution.
Anyway, refer to following document:
http://winscp.net/eng/docs/faq_su
One2Connect
I already tried this page, but unable to get any success.
What specific problem do you have?
