Topic "two ask for powershell script"
rvjhon
I want use a Powershell script for download file on few serveur (20-30).
Can i use WinSCPnet.dll whitout $sessionOptions.SshHostKeyFingerprint ?
And can i read on a file HostName and password ... ?
I have test a many solution with Get-Content and Foreach-Object.
and now i have no idea for creating this script
Thanks so much
King Regards
Jhon
My script:
try
[Reflection.Assembly]::LoadFrom("WinSCPnet.dll") | Out-Null
ForEach ($liste_srv in Get-Content "z:\projet_enable\liste_serveur.txt")
($liste_mdp in Get-Content "z:\projet_enable\liste_mdp.txt")
($liste_ssh in Get-Content "z:\projet_enable\liste_ssh.txt")
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = $liste_srv
$sessionOptions.UserName = "root"
$sessionOptions.Password = $liste_mdp
$sessionOptions.SshHostKeyFingerprint = $liste_ssh
try
$session.GetFiles("/home/gconf/*.gz", "C:\Users\adm-l2b-jherve\test\*").check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
ForEach ($system in Get-Content "liste_serveur.txt")
Write-Host $system
Write-Host " "
exit 1
If you do not care about security you can use SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey.
Do you mean if you can read hostname and password from a file? WinSCP .NET assembly cannot do this directly, but implementing this in PowerShell should be pretty easy. That's out of scope of the forum though.
rvjhon
Thanks prikryl for your help,
would do you help me for this script ?
regards
I do not know PowerShell good enough. Consider asking on stackoverflow.com. Post a link here if you do.
rvjhon
Sorry i dont know use this value.
Where i put this value $sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey
regards mister
$srv = Get-Content "z:\projet_enable\liste_serveur.txt"
$mdp = Get-Content "z:\projet_enable\liste_mdp.txt"
[switch] $IgnoreHostKey = $false
for ($i = 0; $i -le $srv.count-1; $i++){
write-host "etape 1" $srv[$i]
$sessionOptions.HostName = $srv[$i]
$sessionOptions.Password = $mdp[$i]
$sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = $IgnoreHostKey
write-host "etape 2" $srv[$i]
try
write-host "etape 3 Ligne $i correspondant" $srv[$i]
write-host "================="
finally
$session.Dispose()
You have to set it to "true", not "false".
