Topic "Writing commands in batch file"
indraabanerjee
When i write the below two lines in command prompt it works.
If i write the same lines in a bat file and execute, it does not work.
I cant see any error.Also it is not performing the task written in test_indra.txt.
Can you help? it is very urgent.
cd C:\Program Files (x86)\WinSCP
WinSCP /script="test_indra.txt"
Many Thanks
Indraa
indraabanerjee wrote:
it does not work.
What does it do? Any error message?
indraabanerjee
it does not work.
I dont see ny error message.But the test_indra.txt is not getting called.
I understood this because it is not performing whatit is supposed to do i.e coping a file to a rmeotelcoation.
But test_indra.txt is correct because it works when called from command prompt
Any other output (if not error)?
