Upgrading to latest version of Winscp
psharma
India
I want to upgrade my WinSCP version from 5.1.3 to the latest one.
If I do so, what happens to the handshaking of the keys; Do I need to redo again?
Jyl_2015
Upgrading to the latest WinSCP version
All of our automated tasks use WinSCP version 3.82. But due to an automation that requires a passphrase, I need to use the latest version WinSCP 5.72. All of the scripts will be run in the same server so I installed the latest version on the same machine and upgrade it. I saw that the installation folder retains the winscp3 and updates some files only. Would it post a problem if both version will be used? The existing tasks call the winscp3.exe and the new one calls winscp.com.
Thanks.
Jyl
Philippines
Re: Upgrading to the latest WinSCP version
It's not a problem. Just use the winscp.com.
Thanks admin. All of the tasks run via Windows Task Scheduler so I want to make sure that the old/existing scripts that use winscp3.exe would still work (no need to update the script)? I know that this can be answered by testing the scripts in the task scheduler but I can't connect to the sessions due to some access restriction so I can't perform the test.
You can rename the winscp.exe to winscp3.exe. But you should test it nevertheless. While we keep WinSCP as backward-compatible as possible, it's been quite a some time since 3.8.2 (9 years!).
