Topic "create script that synchronizes files and deletes synchroniz"
Mahdi Bashiri
Hi
I have created script that synchronizes files from local path to remote site and deletes source files afterward, but in sometimes the file does not transfer completely by link down or remote site load traffic, i would like to know can i use "-criteria=size" before "-delete" option or no like this:
synchronize remote D:\IscFtp\BLC\SND_SP BLC\SND_SP -criteria=size -delete
please let me know this script line is correct ot need more issue to do this
Regards,
Mahdi
Please read FAQ:
http://winscp.net/eng/docs/faq_delete_synchronized_files
If that does not help, come back.
Mahdi Bashiri
prikryl wrote:
Please read FAQ:
Hi
I used below command to auto transfer (Upload) to remote site:
winscp /command "option batch abort" "option confirm off" "open RemoteSite" "put E:\Backup_*.* / -criteria=size -delete" "exit" > E:\RemoteSiteUpload.txt
but i got below error
batch abort
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "username".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] RemoteSite
Unknown switch 'criteria'.
please let me know how can i fix it.
Regards,
Mahdi
The -criteria is switch of synchronize command, not put.
http://winscp.net/eng/docs/scriptcommand_synchronize
Mahdi Bashiri
Hi
May i ask you to define criteria switch for put command if possible, and i would like to know how can i use syncronise command to upload only specified file ( not entire directory) to remote site.
Regards,
Mahdi
synchronize remote -criteria=size -filemask=file_to_synchronize.ext c:\local_folder /remote_folder
