Topic "Send a log to a file after a script runs"
Joshuas
I have successfully written a script to sync all my SFTP with a cloud storage I have set up. New files are added every day and I have the script being called a few times a day. Question: How can I output the results of the log to a text file or send an email to myself with what the results were or what new files were synched.. Is there a way of doing this?> Help is appreciated mucho mucho
Joshuas
well I figured it out by myself. now how can I add a timestamp to the log
WinSCP session log includes a timestamp.
Possibly you mean something else by a "log" (WinSCP console output redirected to a file?).
Joshuas
No, I as able to add to the winscp script text file by adding !D!M!Y... How can I set it to only tell me what files it added or extract that information from the log?
Also, there seems to be an error everytime I have a batch file called automatically to run the Winscp script. It works great manually, only when using task scheduler do I get issues. Error code 3.
Joshuas
using winscp.com does not solve the problem. Its crazy I can manually run the script no problem but when Task Scheduler tries the world blows up.
It might be this problem:
http://winscp.net/tracker/show_bug.cgi?id=996
Make sure you are using the latest version of WinSCP (and restart your server after upgrade).
