Topic "when synchronize create remote directory if not exists"
unknown
When scripting, can winscp create remote directory (and its parents directories) if not exists?
e.g. when i need to backup the following folders
local "C:\Users\a\Desktop" -> remote "a\Desktop"
local "C:\Users\b\Desktop" -> remote "b\Desktop"
local "C:\Users\c\Desktop" -> remote "c\Desktop"
my script need to do the following:
mkdir a
cd a
lcd a
synchronize Desktop Desktop
cd ..
The root destination directory has to exist prior to synchronization. Any absent sub-directories will be created.
unknown
but when scripting, it is tedious and error-prone, to repeat: mkdir->cd->mkdir->cd->...->synchronize->go to parent directory->..->go to parent directory.
Besides, there is no formal documentation for cd to parent directory.
Not sure, if I understand you. As I wrote, subdirectories are created.
So if you execute: synchronize remote c:\web /home/username/httpdocs only the httpdocs needs to exist.
If there's c:\web\images, but not /home/username/httpdocs/images, the images subfolder is created.
Sometimes there is a need to sync a few subfolders only
e.g. Desktop,Documents,Music insides user profile directory, as there is too many garbage insides
How's that related?
adam
I believe OP desires functionality same as GNU coreutil's "cp --parents"
https://www.gnu.org/software/coreutils/manual/html_node/cp-invocation.html
‘--parents’
Form the name of each destination file by appending to the target directory a slash and the specified name of the source file. The last argument given to cp must be the name of an existing directory. For example, the command:
          cp --parents a/b/c existing_dir
copies the file a/b/c to existing_dir/a/b/c, creating any missing intermediate directories.
Using your example,
mkdir c:\web; cd c:\web
synchronize local -parents c:\web /home/username/httpdocs
if c:\web\home\username\httpdocs does not exist, then
  mkdir home; mkdir home\username; mkdir home\username\httpdocs;
  get /home/username/httpdocs/* c:\web\home\username\httpdocs
else
  synchronize c:\web\home\username\httpdocs /home/username/httpdocs
It is similar to my request of creating empty directories, http://winscp.net/forum/viewtopic.php?t=14131 only implemented at the scripting level. Essentially it allows for retaining a directory structure without having to transfer all parent sibling objects. My desire for this at the GUI level is a user can slowly recreate a remote directory structure on their local drive slowly, as needed. Which makes it easier to synchronize if they have already grabbed a few sub-folders of a target sync directory.
I can see this being a useful enhancement.
As an initial progression to get this functionality included, perhaps a workable goal would be a mkdir -parents option?
https://www.gnu.org/software/coreutils/manual/html_node/mkdir-invocation.html
Thank you for all your hard work on this program!
Thanks for the explanation. Will consider it.
