Topic "Synchronization without deleting local files"
tingtang
Hi! Is there a way to synchronize (or other option) files without deleting local files. For example:
On remote FTP I want to keep 1 monthly old files. On local I want to keep 2 monthly files. I have batch script on FTP server, which deletes files older then 1 month on it. So, after synchronization local files are deleting also. For now I'm saving it with this way: I have local batch script, which is moving 2 monthly files to other folder, so. But are there any way to resolve only with winscp?
Synchronization deletes files only if you instruct it to do so using -delete switch. Just remove it.
http://winscp.net/eng/docs/scriptcommand_synchronize
tingtang
I'm not using that option, how can disable it?
tingtang
Sorry, that's right. It has been added, by some reason). Thank you.
