Topic "WinSCP - Does it support PORT data connection type ?"
psharma
Does WINSCP support PORT data connection type ?
I am getting error - Error listing directory.
When compared with other FTPs, only data connection type is different.
I am able to connect the same FTP using CuteFTP, but not with WinSCP.
Kindly help.
Do you mean WebDAV?
psharma
prikryl wrote:
Do you mean WebDAV?
Oops; what I meant was - Does WinSCP supports "Port" under Data connection type.
Earlier we were using CuteFTP for the same FTP. Under "Data Connnection Type" the value set is - PORT.
If we change it something else, we are not able to access FTP using CuteFTP.
But I dont see any such option in WinSCP.
I am not sure what WebDAV means?
OK, you mean FTP active mode.
Just turn off Passive mode connection settings:
http://winscp.net/eng/docs/ui_login_connection
