Topic "V.5.5.3. B.4214 Scripting - SFTP instead of FTP"
Sessl
I've switched our server from 2k3 to 2k8, installed a new version of WinSCP (4.3.2 > 5.5.3) and copied my script.
After starting WinSCP and configured the connection (FTP address, user, password) and saved as session, I tried the script if its still working, it doesn't.
The problem, in the session I've setup a FTP connection. In the script I called this session:
"C:\Program Files (x86)\WinSCP\WinSCP.com" /log="C:\Program Files (x86)\WinSCP\scp_log.txt" /command "option batch on" "option confirm off" "option transfer automatic" "open my@session" "put ""%target%\%var%""" "close" "exit"
but in the log file I see that the transfer protocol SFTP is used:
. 2014-04-17 11:16:24.680 --------------------------------------------------------------------------
. 2014-04-17 11:16:24.681 WinSCP Version 5.5.3 (Build 4214) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Standard)
. 2014-04-17 11:16:24.681 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2014-04-17 11:16:24.681 Local account: domain\user
. 2014-04-17 11:16:24.681 Working directory: D:\usr\sap\SID\DVEBMGS00\work
. 2014-04-17 11:16:24.681 Process ID: 3300
. 2014-04-17 11:16:24.681 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=553 /consoleinstance=_10228_912 "/log=C:\Program Files (x86)\WinSCP\scp_log.txt" "/command" "option batch on" "option confirm off" "option transfer automatic" "open my@session" "put ""\\target\0000137084.pdf""" "close" "exit"
. 2014-04-17 11:16:24.681 Time zone: Current: GMT+2, Standard: GMT+1 (W. Europe Standard Time), DST: GMT+2 (W. Europe Daylight Time), DST Start: 3/30/2014, DST End: 10/26/2014
. 2014-04-17 11:16:24.681 Login time: Thursday, April 17, 2014 11:16:24 AM
. 2014-04-17 11:16:24.681 --------------------------------------------------------------------------
. 2014-04-17 11:16:24.681 Script: Retrospectively logging previous script records:
> 2014-04-17 11:16:24.681 Script: option batch on
< 2014-04-17 11:16:24.681 Script: batch           on
> 2014-04-17 11:16:24.681 Script: option confirm off
< 2014-04-17 11:16:24.681 Script: confirm         off
> 2014-04-17 11:16:24.681 Script: option transfer automatic
< 2014-04-17 11:16:24.681 Script: transfer        automatic
> 2014-04-17 11:16:24.681 Script: open my@session
. 2014-04-17 11:16:24.681 Session name: my@session (Ad-Hoc site)
. 2014-04-17 11:16:24.681 Host name: 192.168.1.1 (Port: 22)
. 2014-04-17 11:16:24.681 User name: USER (Password: No, Key file: No)
. 2014-04-17 11:16:24.681 Tunnel: No
. 2014-04-17 11:16:24.681 Transfer Protocol: SFTP (SCP)
. 2014-04-17 11:16:24.681 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2014-04-17 11:16:24.681 Proxy: none
. 2014-04-17 11:16:24.681 Send buffer: 262144
. 2014-04-17 11:16:24.681 SSH protocol version: 2; Compression: No
. 2014-04-17 11:16:24.681 Bypass authentication: No
. 2014-04-17 11:16:24.681 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2014-04-17 11:16:24.681 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2014-04-17 11:16:24.681 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2014-04-17 11:16:24.681 Simple channel: Yes
. 2014-04-17 11:16:24.681 Return code variable: Autodetect; Lookup user groups: A
. 2014-04-17 11:16:24.681 Shell: default
. 2014-04-17 11:16:24.681 EOL: 0, UTF: 2
. 2014-04-17 11:16:24.681 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2014-04-17 11:16:24.681 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2014-04-17 11:16:24.681 SFTP Bugs: A,A
. 2014-04-17 11:16:24.681 SFTP Server: default
. 2014-04-17 11:16:24.681 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2014-04-17 11:16:24.681 Cache directory changes: Yes, Permanent: Yes
. 2014-04-17 11:16:24.681 DST mode: 1; Timezone offset: 0h 0m
. 2014-04-17 11:16:24.682 --------------------------------------------------------------------------
. 2014-04-17 11:16:24.682 Looking up host "192.168.1.1"
. 2014-04-17 11:16:24.682 Connecting to 192.168.1.1 port 22
I've also tried the old version, but I get the same error.
So, what is the problem, why is WinSCP switching from FTP to SFTP and why is my script not working anymore, because I don't changed anything.
I just wanna ask before I will change my script ..
Thanks for any advise!
Best regards,
Tobias
Sessl
After checking the log file again and again and ag... I found a row that differs from the old log:
On your very good support side I found out, that I have to use doubling double-quotes! Which I forgot on the open command!
"C:\Program Files (x86)\WinSCP\WinSCP.com" /log="C:\Program Files (x86)\WinSCP\scp_log.txt" /command "option batch on" "option confirm off" "option transfer automatic" "open ""my@session""" "put ""%target%\%var%""" "close" "exit"
Don't know why it works before, but now I found the solution.
Thanks for your support side!
Tobias
[edit]
The double-quotes weren't the problem, because my used session uses the reg entry from a wrong user. I've exported my session to the *.ini file and use that file instead of the registry entry.
[/edit]
