Topic "Right Click is not working on the local directory (left pane"
Issue: Right Click is not working on the local directory (left pane) after connecting from home remotely.
Description: When I connect from home remotely to my workstation in office and work with Winscp, it works fine but when I come to office and login to my workstation, I see that the right mouse button does not work and hence does not show any menu. It just works fine with the Remote dircetory (right pane).
Winscp Version - 5.5.3
The problem has been there since I have started using Winscp from the beginning.
Windows 7 professional 32-bit
GUI, Interface Style - Commander
You can contact me @
Are you using standard Windows RDP client?
