Topic "drag n drop from remote problem [SOLVED]"
rodia
WinSCP freezes before uploading file
WinSCP v5.5.3 on Windows 8.1 x64 Pro
Commander interface
Session protocol = SSH-2
SSH implementation = OpenSSH_6.2p2 Ubuntu-7netart1
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-3
tried to restart system many times but with no result
Ok I solved this problem.
I changed my old HDD on SSD so partition letters have been changed. After importing config file (WinSCP.ini)in settings->temporary directory ->use this directory... was letter of non existent partition so WinSCP was not able to use this partition and appeared dysfunction. When I pointed to the correct partition everything runs smoothly.
Regards,
