Topic "Open with"
Open with
I have sonme file types which i want to open with different Editors:
for example:
- jpg
default: windows picture view
- open with: Adobe Photoshop
- open with: Gimp
So I have one File Type for different Editors.
Ist it possible to add the open with dialog on right click from windows?
Thanks for your suggestion. Will see if more people ask for this.
Jibbs
This would be a nice feature. However in the mean time you can go to Options > Preferences > Panels > Local and checkmark "Use system file context menu"
nice feature for changing files (comfort feature)
Hombl
I have the same problem.
I have some config files (*.conf) which I have to
open with different editors (ultraedit and the integrated editor)
nobody
WinSCP Edit With menu (named Edit (alternative) in current release) added to file panel context menu:
http://winscp.net/tracker/show_bug.cgi?id=1226
Open with
perfect - thank you very much!
