Topic "Tunnel password not updating"
marutuk
At our work we have to connect to our servers using a Tunneled connection and make use of WinSCP feature to store the Tunnel data which is working fine for stored sessions. However we are starting to have issues with the more recent versions of WinSCP where, after upgrading the tunnel password to a new one, where we will receive an Access Denied error from the server.
Could it be that the password does not get updated in the place WinSCP stores it?
Thanks for checking on this.
I was not able to reproduce the problem you are describing.
How did you "upgrade the tunnel password to a new one"?
marutuk
This was done by editing the profile, changing the password for the Tunnel part and saving it.
Oddly enough, after changing this, it doesn't seem to store the updated password as the initial login attempt does fail with an access denied.
marutuk
prikryl wrote:
Thanks, that actually helped pinpoint the issue: as we have to use a secondary token for logging in besides the password, this appears where it goes wrong as it tries to automatically enter the password in the PASSCODE prompt as well:
! 2014-05-21 18:17:11.931 [Tunnel] Using username "XXXXXXXXXXXXXXXXXXX".
. 2014-05-21 18:17:12.025 [Tunnel] Attempting keyboard-interactive authentication
. 2014-05-21 18:17:12.093 [Tunnel] Prompt (6, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2014-05-21 18:17:12.094 [Tunnel] Using stored password.
. 2014-05-21 18:17:12.233 [Tunnel] Prompt (6, SSH server authentication, Using keyboard-interactive authentication., PASSCODE: )
. 2014-05-21 18:17:12.233 Using remembered password.
. 2014-05-21 18:17:14.887 [Tunnel] Keyboard-interactive authentication failed
! 2014-05-21 18:17:14.887 [Tunnel] Access denied
. 2014-05-21 18:17:14.895 [Tunnel] Attempting keyboard-interactive authentication
. 2014-05-21 18:17:14.962 [Tunnel] Prompt (6, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2014-05-21 18:17:19.156 [Tunnel] Prompt (6, SSH server authentication, Using keyboard-interactive authentication., PASSCODE: )
. 2014-05-21 18:17:21.726 [Tunnel] Prompt (6, SSH server authentication, , <no prompt>)
. 2014-05-21 18:17:21.726 [Tunnel] Ignoring empty SSH server authentication request
. 2014-05-21 18:17:21.727 [Tunnel] Access granted
If you need more data, please let me know. This was using version 5.5.3
http://winscp.net/tracker/show_bug.cgi?id=1176
I'll send you a dev version for testing shortly to your email address.
marutuk
Thanks. Let me know when it's send, as that email box is a bit full of spam as it's my standard "register for things" email account. :)
I've sent it already, shortly after my post above.
marutuk
Would you be able to resend it, I can't seem to find it in my email.
Thanks!
Resent.
I have responded to your email.
marutuk
Thanks.
We tested that build here at work and it does resolve the issue for us.
Thanks for your feedback.
