Topic "Need help in scripting/Automation"
bilal
Hi Experts,
I need your help, i have installed and set up WINSCP i want sync my local directory with remote directory on daily basis so i could run data base check on my local machine, i don't want to delete or change remote directory the direction should be towards local only, my setup is using FTP, remote directory is /opt/backup/ftpboot/backup and local directory is G:\Backup
when i run the .bat file its not working i think i need to modify the script but i don't have expertise to do that Sad i have pure telecom background no scripting skills.
I would be very thankfull to you guys for you help.
Can you share your current script?
See also:
http://winscp.net/eng/docs/troubleshooting#scripting
Thanks for your response prikryl, below is the script
[Configuration]
JumpList=test,SFTP1
That's not a script, that's an configuration INI file.
I have removed it as it contains your root password.
