Topic "Space in filename SynchronizeDirectories"
anders
Hi everybody,
I get an exception when trying to use the SynchronizeDirectories method on a folder containing files with a space character in its filename. I realize that you can use quotes in the command line version, but have do I handle it in the .NET assembly?
WinSCP .NET assembly can handle paths with spaces.
To generate log file, set Session.SessionLogPath. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
anders
I found out that it was actually a problem on the server side, which has been fixed now.
Thank you for taking the time to answer.
