Topic "Progress Bar shows momentarily using .NET in Powershell 4.0"
mwetmore
Running in Powershell ISE or in CMD.EXE a progress bar flashes up for a moment. How to prevent this? The script will be run by a scheduler. Not using sync, just $session.PutFiles() and $session.GetFiles() for transfers, all piped to Out-Null.
BTW at http://winscp.net/eng/docs/library_example_listing_files_matching_wildcard this:
foreach ($fileInfo in $directory.Files)
should be:
foreach ($fileInfo in $Files)
What progress bar do you mean?
mwetmore
When running the ps1 in 4.0 ISE by clicking Arrow to execute the console shows the full path to the script, then just before the script exits a GUI blue progress bar flashes up on the top of the console. It is a very quick flash, I have to be staring at the right place to see that the short disturbance.
Similarly when I run the script by invoking powershell in a cmd window, there is a quick flash of 'ooo...' that moves across the top of the window.
These are all the assembly methods used, in the order that they occur. The script runs in < 30 seconds
 # SFTP does not have an append verb so it has to be get->append->put
        $rem = "{0}{1}" -f $carrdir, $rcdf
        if ($send -eq "R" -and $session.FileExists($rem)) {
            if ($session.GetFiles($rem, $rcdtemp).IsSuccess) {
                $session.RemoveFiles($rem) | Out-Null
                Get-Content ($rcdtemp) |
                    Add-Content ("{0}\{1}" -f $temploc, $rcdf)
            } else {
                CleanUp-Exit(2)
        # This creates a directory in $carrdir named like $temploc
        $session.PutFiles($temploc, $carrdir).Check() | Out-Null
        # Get list of files uploaded
        $files = $session.ListDirectory($carrloc).Files | Where { -not $_.IsDirectory }
            # Move the files up into $carrdir
            ForEach ($fileinfo in $files) {
                $session.MoveFile($carrloc + "/" + $fileinfo.Name, $carrdir)
   if ($session.Opened) {
        $session.RemoveFiles($carrloc) | Out-Null
        $session.Dispose()
WinSCP .NET assembly does not present any progress bar (it has no GUI at all). So it has to be your run-time environment that shows the progress bar.
