Topic "Improvements in the Internal Editor"
nbohra
The internal editor is a great tool and I perfer to use it. But it is missing a couple of items/toggle
1) Show line numbers
2) Option to show multiple editors as 'tabs' in one window -- easier for cut/paste
3) "Tail" mode -- scroll to bottom and reload/refresh on changes
Thanks for a great product
Thanks for your suggestions. Though we do not plan to make big improvements to internal editor. If you need a better editor, consider using an external editor with WinSCP.
Please reconsider to improve the editor!
IMO it needs:
fg/bg color
horizontal split to view/edit two section of a file
thank you..
Thanks for your suggestion.
Note that background color can be changed:
http://winscp.net/tracker/show_bug.cgi?id=480
http://winscp.net/eng/docs/ui_editor
