Topic "Using Tar/GZip causes many reconnects and blocks the program"
xantiva
I'm running WinSCP 5.5.3 on a Windows 7 64bit (Pro) computer. If I use the "Tar/Gzip" on a lot of files in the past, the process starts on the server, WinSCP shows ONCE a "server isn't responding" message. After that, I could "reconnect" with this dialog and continue working. If I refresh, I could see that the archive is still increasing.
With the actual WinSCP Version, the process starts and after some seconds the "server isn't responding" dialog opens (as before). But it disappears immediately without a chance to click! The program is blocked and after a short time the dialog appears and disappears again. This continues until the tar - process is ready.
Is this a new feature or maybe a bug? I prefer the old behavior Wink
Thank you for your work with WinSCP and best regards,
Mike
The "not responding" box disappears when your server responds (= sends any data). Possibly the tar outputs some progress?
xantiva
sorry for my late response. Seems that I miss the notification about new posts ...
I don't know. Sad How can I check this?
The main problem is, that WinSCP is blocked through the hole time. In the past I could continue working ...
Best regards,
Mike
