Topic "No links created or not visible"
wdburgdorf
I just tried to create links, but after creation, they don't show up.
When trying to create the same link twice, I get an error message, though:
General failure (server should provide error description).
Error code: 4
Error message from server (en-US): File already exists
WinSCP 5.5.2 / 4130
FTP, shared hosting, no root access.
I did read the manual about this ...
I tried various combinations of files and subdirectories, with and without initial slash.
Thanks for your help!
Regards,
Ralf.
wdburgdorf
Hi prikryl,
Thanks for your answer. I installed the latest version, 5.5.3-4214 and repeated linktesting with logging on, set to "normal". I removed the file listings from the log. Please find it attached.
log - creating link.txt (1.61 KB) [Download]
Description: (none)
File listing is what I wanted to see. Can you please attach a complete log file showing session opening, symlink creation and subsequent directory listing?
wdburgdorf
E-Mail sent.
I have filed two related bugs with ProFTPD/mod_sftp (the SFTP server you are using):
Reversed order of SSH_FXP_SYMLINK arguments:
http://bugs.proftpd.org/show_bug.cgi?id=4080
Not possible to create relative symlinks with SFTP:
http://bugs.proftpd.org/show_bug.cgi?id=4081
I have also changed WinSCP to workaround the first bug automatically:
http://winscp.net/tracker/show_bug.cgi?id=1185
davidmartin123
prikryl wrote:
I was also facing the same problem but having implemented your advise, I got out of the mess.
