Topic "Corrupted files during SFTP synchronization"
mateusz.naskret
I have very strange problem with corrupted files during synchronization over SFTP. I have no idea how it is possible but after synchronization some files (I am sending only PHP files) are mixed - in updated file there is part of old file. Updated file has a correct file size and date - but in content there is one "segment" from old file.
Synchronization is done via scripting: synchronize command with switches: -mirror -delete -permissions=755
I am using WinSCP v. 5.1.4 on Windows XP machine.
Can you reproduce this easily or does it happen randomly?
mateusz.naskret
I cannot reproduce it "on demand" but i have noticed that it happens only when there was no changes in source folder for a longer time (few days), so few days there was nothing to synchronize.
Can you enable logging and attach a log file for a respective session once the problem occurs?
mateusz.naskret
I have upgraded WinSCP to latest version 3 weeks ago. From this time it didn't happen again. I will write again if it will occur again.
mateusz.naskret
I am writting again becouse problem is still not solved.
We are using now Winscp v.5.5.3 (build 4214).
There is a change in what i described before.
What is happening: file has repeated content at the end (see example in attachment).
When it is happening:
- we have a automatic job that executes:
put D:\GIO3\sip\css_sip\naglowek.inc  /incoming/htdocs/css_sip/naglowek.inc -resume  -permissions=755
- problem occures only in case when i edit a destination file so it has newer date than a source file (i am not sure if it matters but i am adding something to destination file and then removing it so the file content before and after my change is the same)
I am wondering how "resume" option is working ? Do i need it ? Anyway i think something is wrong.
naglowek.inc.corrupted.txt (16.49 KB) Private file
Description: Example of corrupted file - check repeated content at the end.
You do not want to use the -resume, unless you really want to resume a previously interrupted download, and you are sure that neither the source nor the destination file has changed since the interrupted transfer.
