Topic "*.eps - connection reset by peer"
been trying to copy eps files created by corel draw.
it would usually copy half then display a "connection reset by peer".
1. let me know if you want a sample .eps file.
2. i've contacted the sys admin for the sshd server.
they said there were no error logged.
they have increased logging from "info" to "verbose"
they are using OpenSSH_3.5p1 FreeBSD.
3. can copy *.eps files using ftp
4. can copy *.eps files using cyberduck (mac osx)
5. tried sending zipped *.eps files. same problem
any help would be appreciated. thanks again from creating winscp.
What protocol? SCP or SFTP? Can you post a log file?
