Topic "Can't open data connection after a while"
kimr-dk
Hi
Both with the commands "synchronize local -delete -mirror" and "get * -resume" after it have downloaded many files, I've suddenly got:
2006092                   |            0 B |   51,2 KiB/s | binary |   0%
1.jpg                     |         39 KiB |   54,8 KiB/s | binary | 100%
2.jpg                     |         37 KiB |   56,4 KiB/s | binary | 100%
2006093                   |            0 B |   56,4 KiB/s | binary |   0%
1.jpg                     |         39 KiB |   54,1 KiB/s | binary | 100%
2.jpg                     |         37 KiB |   55,6 KiB/s | binary | 100%
2006094                   |            0 B |   55,6 KiB/s | binary |   0%
1.jpg                     |         39 KiB |   56,8 KiB/s | binary | 100%
2.jpg                     |         37 KiB |   50,1 KiB/s | binary | 100%
2006095                   |            0 B |   50,1 KiB/s | binary |   0%
Error listing directory '/Product/2006095'.
Can't open data connection for transfer of "/Product/2006095"
2006095                   |            0 B |   33,7 KiB/s | binary |   0%
It's random when the error appear.
I try to download/update local files from the server, so it won't have to download all files every time.
It seems to be a server error, but I can't figure out why.
Any ideas?
/Kim
kimr-dk
Think I found it... passive FTP 101 Smile
As the FTP server is FileZilla, I found on https://wiki.filezilla-project.org/Network_Configuration#Passive_mode_2
"Due to the nature of TCP (the underlying transport protocol), a port cannot be reused immediately after each connection. Hence the range of ports should not be too small or transfers of multiple small files can fail. A range of 50 ports should be sufficient in most cases."
I've opened a lot more ports and now it seems to work.
Thanks for sharing the solution.
