Topic "Cannot download from specific FTP server with WinSCP.com"
eldnumh
I want to download a file from an FTP server owned by a huge European agency. A few month ago it work perfectly, but now, the download fails with:
Could not retrieve file information
Command was blocked. Contact admin.
The commands I am using are
"\Program Files (x86)\WinSCP\WinSCP.com" /log="winscp.log"
open ftp://...
get /dsf/fr/y20...
For me it seem, that WinSCP.com calls MLST before actually retrieving the file. Is this correct, why is this required? It it possible to disable that?
If I call stat, I get the same error.
If I use the GUI, I can download the file without error.
The log was created with winscp v 5.1.7, but I tested with 5.5.3 either, this version shows the same error message.
Win7 64bit
FTP
no GUI
Quote:
. 2014-06-02 10:20:50.985 --------------------------------------------------------------------------
. 2014-06-02 10:20:50.986 WinSCP Version 5.1.7 (Build 3446) (OS 6.1.7601 Service Pack 1)
. 2014-06-02 10:20:50.986 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2014-06-02 10:20:50.987 Local account: IXENXOM\hmu
. 2014-06-02 10:20:50.987 Working directory: C:\Users\hmu.IXENXOM
. 2014-06-02 10:20:50.987 Process ID: 5092
. 2014-06-02 10:20:50.987 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=517 /consoleinstance=_4916_111 "/log=winscp.log"
. 2014-06-02 10:20:50.987 Time zone: Current: GMT+2, Standard: GMT+1, DST: GMT+2, DST Start: 30.03.2014, DST End: 26.10.2014
. 2014-06-02 10:20:50.987 Login time: Montag, 2. Juni 2014 10:20:50
. 2014-06-02 10:20:50.987 --------------------------------------------------------------------------
. 2014-06-02 10:20:50.987 Session name: EXittXann@ftparch.giove.xxx.int (Modified stored session)
. 2014-06-02 10:20:50.987 Host name: ftparch.giove.xxx.int (Port: 21)
. 2014-06-02 10:20:50.987 User name: EXittXann (Password: Yes, Key file: No)
. 2014-06-02 10:20:50.987 Tunnel: No
. 2014-06-02 10:20:50.987 Transfer Protocol: FTP
. 2014-06-02 10:20:50.987 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2014-06-02 10:20:50.987 Proxy: none
. 2014-06-02 10:20:50.987 FTP: FTPS: None; Passive: Yes [Force IP: A]; List all: A
. 2014-06-02 10:20:50.987 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2014-06-02 10:20:50.987 Cache directory changes: Yes, Permanent: Yes
. 2014-06-02 10:20:50.987 DST mode: 1; Timezone offset: 0h 0m
. 2014-06-02 10:20:50.996 Connecting to ftparch.giove.xxx.int ...
. 2014-06-02 10:20:51.047 Connected with ftparch.giove.xxx.int. Waiting for welcome message...
< 2014-06-02 10:20:51.074 220 Check Point FireWall-1 Secure FTP server running on FW-ESA-01
> 2014-06-02 10:20:51.075 USER EXittXann
< 2014-06-02 10:20:51.104 331 password: you can use password@password
> 2014-06-02 10:20:51.104 PASS *****************
< 2014-06-02 10:20:51.334 230-User EXittXann authenticated by FireWall-1 authentication
< 2014-06-02 10:20:51.334 230-Connected to server. Logging in...
< 2014-06-02 10:20:51.344 230-220 ProFTPD 1.3.4c Server (GPCARC ProFTPD Server) [172.17.0.10]
< 2014-06-02 10:20:51.344 230-331 Password required for EXittXann
< 2014-06-02 10:20:51.344 230-230-*******************************************************************************
< 2014-06-02 10:20:51.344 230- IT IS AN OFFENCE TO CONTINUE WITHOUT PROPER AUTHORISATION. This system is
< 2014-06-02 10:20:51.344 230- restricted to authorised users .
< 2014-06-02 10:20:51.344 230- Individuals attempting unauthorised access will be prosecuted.
< 2014-06-02 10:20:51.344 230- *******************************************************************************
< 2014-06-02 10:20:51.344 230 230 User EXittXann logged in
> 2014-06-02 10:20:51.344 SYST
< 2014-06-02 10:20:51.366 215 UNIX Type: L8
> 2014-06-02 10:20:51.366 FEAT
< 2014-06-02 10:20:51.396 211-Features:
< 2014-06-02 10:20:51.632 MDTM
< 2014-06-02 10:20:51.632 MFMT
< 2014-06-02 10:20:51.632 TVFS
< 2014-06-02 10:20:51.632 MFF modify;UNIX.group;UNIX.mode;
< 2014-06-02 10:20:51.632 MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2014-06-02 10:20:51.632 REST STREAM
< 2014-06-02 10:20:51.632 SIZE
< 2014-06-02 10:20:51.632 211 End
. 2014-06-02 10:20:51.633 Connected
. 2014-06-02 10:20:51.633 --------------------------------------------------------------------------
. 2014-06-02 10:20:51.634 Using FTP protocol.
. 2014-06-02 10:20:51.634 Doing startup conversation with host.
> 2014-06-02 10:20:51.635 PWD
< 2014-06-02 10:20:51.664 257 "/" is the current directory
. 2014-06-02 10:20:51.665 Getting current directory name.
. 2014-06-02 10:20:51.666 Startup conversation with host finished.
< 2014-06-02 10:20:51.666 Script: Active session: [1] EXittXann@ftparch.giove.xxx.int
> 2014-06-02 10:22:16.808 Script: get /dsf/fr/y2013/m06/d30/h07/GNA/GNARNAVS999913181HMRAWF000.xml.gz
. 2014-06-02 10:22:16.809 Listing file "/dsf/fr/y2013/m06/d30/h07/GNA/GNARNAVS999913181HMRAWF000.xml.gz".
> 2014-06-02 10:22:16.810 REST 0
< 2014-06-02 10:22:16.810 502 Security server inhibited REST command
> 2014-06-02 10:22:16.810 PWD
< 2014-06-02 10:22:16.810 257 "/" is the current directory
. 2014-06-02 10:22:16.810 Retrieving file information...
> 2014-06-02 10:22:16.810 MLST /dsf/fr/y2013/m06/d30/h07/GNA/GNARNAVS999913181HMRAWF000.xml.gz
< 2014-06-02 10:22:16.854 505 Command was blocked. Contact admin.
. 2014-06-02 10:22:16.854 Could not retrieve file information
< 2014-06-02 10:22:16.855 Script: Can't get attributes of file '/dsf/fr/y2013/m06/d30/h07/GNA/GNARNAVS999913181HMRAWF000.xml.gz'.
< 2014-06-02 10:22:16.856 Script: Could not retrieve file information
< 2014-06-02 10:22:16.857 Command was blocked. Contact admin.
. 2014-06-02 10:22:16.858 Script: Failed
> 2014-06-02 10:22:22.039 Script: bye
. 2014-06-02 10:22:22.040 Script: Exit code: 1
. 2014-06-02 10:22:22.041 Disconnected from server
In scripting WinSCP uses MLST command to find out if the path points to a file or directory. In GUI, WinSCP already knows that from directory listing. I just wonder if MLSD works (as listing in GUI obviously works). But, I do not understand what's would be a point of disabling MLST, but allowing MLSD.
Anyway, obvious problem is that your server announces support for MLST command, although it actually does not allow it.
As a workaround you can:
  • Configure WinSCP to fallback to LIST (with all its disadvantages):
    http://winscp.net/eng/docs/ui_login_ftp
    http://winscp.net/eng/docs/rawsettings
  • Use file mask instead of specific path, i.e. get /dsf/fr/y2013/m06/d30/h07/GNA/GNARNAVS999913181HMRAWF000.xml.gz* (note the asterisk).
    This makes WinSCP use MLSD to get list of all files to search for names matching mask. I.e. effectively doing what GUI does.
eldnumh
MLSD works...
Currently I am trying to get this changed on the FTP server, but it is a huge European agency, therefore this will probably take months...
This workaround does not help, it only changes the behaviour for ls from MLSD to LIST -a, but stat or get still uses MLST.
See the following logfile:
. 2014-06-04 14:11:37.765 --------------------------------------------------------------------------
. 2014-06-04 14:11:37.765 WinSCP Version 5.5.3 (Build 4214) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2014-06-04 14:11:37.765 Configuration: nul
. 2014-06-04 14:11:37.765 Local account: UPN2\UMF-Admin1
. 2014-06-04 14:11:37.765 Working directory: C:\Users\UMF-Admin1
. 2014-06-04 14:11:37.765 Process ID: 1280
. 2014-06-04 14:11:37.765 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=553 /consoleinstance=_4968_516 "/ini=nul" "/log=winscp.log" "/command" "open ftp://EXittXann:xxx@ftparch.giove.xxx.int/dsf/fr/ -rawsettings FtpUseMlsd=1" "ls"
. 2014-06-04 14:11:37.765 Time zone: Current: GMT+2, Standard: GMT+1 (W. Europe Standard Time), DST: GMT+2 (W. Europe Daylight Time), DST Start: 3/30/2014, DST End: 10/26/2014
. 2014-06-04 14:11:37.765 Login time: Wednesday, June 04, 2014 2:11:37 PM
. 2014-06-04 14:11:37.765 Script: Retrospectively logging previous script records:
> 2014-06-04 14:11:37.765 Script: open ftp://EXittXann:***@ftparch.giove.xxx.int/dsf/fr/ -rawsettings FtpUseMlsd=1
. 2014-06-04 14:11:37.765 Session name: EXittXann@ftparch.giove.xxx.int (Ad-Hoc site)
. 2014-06-04 14:11:37.765 Host name: ftparch.giove.xxx.int (Port: 21)
. 2014-06-04 14:11:37.765 User name: EXittXann (Password: Yes, Key file: No)
. 2014-06-04 14:11:37.765 Tunnel: No
. 2014-06-04 14:11:37.765 Transfer Protocol: FTP
. 2014-06-04 14:11:37.765 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2014-06-04 14:11:37.765 Proxy: none
. 2014-06-04 14:11:37.765 Send buffer: 262144
. 2014-06-04 14:11:37.765 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: - [List all: A]
. 2014-06-04 14:11:37.765 Local directory: default, Remote directory: /dsf/fr/, Update: Yes, Cache: Yes
. 2014-06-04 14:11:37.765 Cache directory changes: Yes, Permanent: Yes
. 2014-06-04 14:11:37.765 DST mode: 1; Timezone offset: 0h 0m
. 2014-06-04 14:11:37.766 Connecting to ftparch.giove.xxx.int ...
. 2014-06-04 14:11:37.796 Connected with ftparch.giove.xxx.int. Waiting for welcome message...
< 2014-06-04 14:11:37.821 220 Check Point FireWall-1 Secure FTP server running on FW-ESA-01
> 2014-06-04 14:11:37.821 USER EXittXann
< 2014-06-04 14:11:37.889 230 230 User EXittXann logged in
> 2014-06-04 14:11:37.889 SYST
< 2014-06-04 14:11:37.919 215 UNIX Type: L8
> 2014-06-04 14:11:37.919 FEAT
< 2014-06-04 14:11:37.941 211-Features:
< 2014-06-04 14:11:38.161  MDTM
< 2014-06-04 14:11:38.162  MFMT
< 2014-06-04 14:11:38.162  TVFS
< 2014-06-04 14:11:38.162  MFF modify;UNIX.group;UNIX.mode;
< 2014-06-04 14:11:38.162  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2014-06-04 14:11:38.162  REST STREAM
< 2014-06-04 14:11:38.162  SIZE
< 2014-06-04 14:11:38.162 211 End
. 2014-06-04 14:11:38.162 Connected
. 2014-06-04 14:11:38.162 --------------------------------------------------------------------------
. 2014-06-04 14:11:38.162 Using FTP protocol.
. 2014-06-04 14:11:38.162 Doing startup conversation with host.
> 2014-06-04 14:11:38.233 Script: ls
. 2014-06-04 14:11:38.233 Retrieving directory listing...
> 2014-06-04 14:11:38.233 TYPE A
< 2014-06-04 14:11:38.259 200 Type set to A
> 2014-06-04 14:11:38.260 PASV
< 2014-06-04 14:11:38.281 227 Entering Passive Mode (195,169,140,174,210,188)
> 2014-06-04 14:11:38.281 LIST -a
< 2014-06-04 14:11:38.339 150 Opening ASCII mode data connection for file list
. 2014-06-04 14:11:38.346 drwxrwxr-x  21 root     root           21 Feb 11 13:00 .
. 2014-06-04 14:11:38.346 drwxr-xr-x  14 root     root           16 Jun  4 05:00 ..
. 2014-06-04 14:11:38.347 drwxr-xr-x   8 root     root            8 Jun  1 00:15 y2014
< 2014-06-04 14:11:38.561 226 Transfer complete
. 2014-06-04 14:11:38.561 Directory listing successful
. 2014-06-04 14:11:38.561 ..;D;0;1899-12-30T01:00:00.000Z;"" [0];"" [0];---------;0
. 2014-06-04 14:11:38.561 y2014;D;8;2014-05-31T22:15:00.000Z;"root" [0];"root" [0];rwxr-xr-x;0
< 2014-06-04 14:11:38.561 Script: D---------   0                           0              ..
< 2014-06-04 14:11:38.568 Script: Drwxr-xr-x   0 root     root             8 Jun  1  0:15 y2014
> 2014-06-04 14:12:25.265 Script: stat /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-04 14:12:25.266 Listing file "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz".
> 2014-06-04 14:12:25.266 TYPE I
< 2014-06-04 14:12:25.266 200 Type set to I
. 2014-06-04 14:12:25.266 Retrieving file information...
> 2014-06-04 14:12:25.266 MLST /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
< 2014-06-04 14:12:25.287 505 Command was blocked. Contact admin.
. 2014-06-04 14:12:25.287 Could not retrieve file information
< 2014-06-04 14:12:25.288 Script: Can't get attributes of file '/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz'.
< 2014-06-04 14:12:25.288 Script: Could not retrieve file information
< 2014-06-04 14:12:25.288 Command was blocked. Contact admin.
. 2014-06-04 14:12:25.289 Script: Failed
> 2014-06-04 14:12:33.681 Script: get /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-04 14:12:33.681 Listing file "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz".
. 2014-06-04 14:12:33.681 Retrieving file information...
> 2014-06-04 14:12:33.681 MLST /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
< 2014-06-04 14:12:33.703 505 Command was blocked. Contact admin.
. 2014-06-04 14:12:33.703 Could not retrieve file information
< 2014-06-04 14:12:33.703 Script: Can't get attributes of file '/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz'.
< 2014-06-04 14:12:33.703 Script: Could not retrieve file information
< 2014-06-04 14:12:33.703 Command was blocked. Contact admin.
. 2014-06-04 14:12:33.704 Script: Failed
> 2014-06-04 14:12:47.985 Script: get /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz*
. 2014-06-04 14:12:47.985 Retrieving directory listing...
> 2014-06-04 14:12:47.985 CWD /dsf/fr/y2014/m03/d15/h13/OSP/
< 2014-06-04 14:12:48.007 250 CWD command successful
> 2014-06-04 14:12:48.007 PWD
< 2014-06-04 14:12:48.027 257 "/dsf/fr/y2014/m03/d15/h13/OSP" is the current directory
> 2014-06-04 14:12:48.027 TYPE A
< 2014-06-04 14:12:48.049 200 Type set to A
> 2014-06-04 14:12:48.049 PASV
< 2014-06-04 14:12:48.071 227 Entering Passive Mode (195,169,140,174,137,95)
> 2014-06-04 14:12:48.071 LIST -a
< 2014-06-04 14:12:48.121 150 Opening ASCII mode data connection for file list
. 2014-06-04 14:12:48.127 drwxr-xr-x   2 root     root           45 Mar 17 14:00 .
. 2014-06-04 14:12:48.127 drwxrwxr-x   6 root     root          189 Apr  3 15:06 ..
. 2014-06-04 14:12:48.127 -rw-r--r--   1 root     root         5595 Mar 17 14:00 OSPRIONO999914074NASEDF000.xml.gz
. 2014-06-04 14:12:48.128 -rw-r--r--   1 root     root         6204 Mar 17 14:00 OSPROSRT999914074NVSISA000.xml.gz
< 2014-06-04 14:12:48.345 226 Transfer complete
. 2014-06-04 14:12:48.345 Directory listing successful
. 2014-06-04 14:12:48.345 ..;D;0;1899-12-30T01:00:00.000Z;"" [0];"" [0];---------;0
. 2014-06-04 14:12:48.345 OSPRIONO999914074NASEDF000.xml.gz;-;5595;2014-03-17T13:00:00.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2014-06-04 14:12:48.345 OSPROSRT999914074NVSISA000.xml.gz;-;6204;2014-03-17T13:00:00.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2014-06-04 14:12:48.346 File: '/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz' [2014-03-17T13:00:00.000Z] [2578]
. 2014-06-04 14:12:48.346 Copying "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz" to local directory started.
. 2014-06-04 14:12:48.346 Binary transfer mode selected.
. 2014-06-04 14:12:48.347 Starting download of /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
> 2014-06-04 14:12:48.348 TYPE I
< 2014-06-04 14:12:48.369 200 Type set to I
> 2014-06-04 14:12:48.369 PASV
< 2014-06-04 14:12:48.391 227 Entering Passive Mode (195,169,140,174,239,7)
> 2014-06-04 14:12:48.391 RETR OSPRIONO999914074NIDFSS000.xml.gz
< 2014-06-04 14:12:48.451 150 Opening BINARY mode data connection for OSPRIONO999914074NIDFSS000.xml.gz (2578 bytes)
< 2014-06-04 14:12:48.675 226 Transfer complete
. 2014-06-04 14:12:48.675 Download successful
> 2014-06-04 14:12:51.825 Script: exit
. 2014-06-04 14:12:51.825 Script: Exit code: 1
. 2014-06-04 14:12:51.825 Disconnected from server
Thanks, this one is working fine Smile
Regards Heiko
You are right. Added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=1181
I'll send you a dev build with the fix.
eldnumh
Thanks for the fix, today I could test it successfully. Here is a part of the log file:
First with calling stat before get
. 2014-06-17 14:24:43.585 WinSCP Version 5.6 (Dev Build 4425 2014-06-10) - Do NOT distribute (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2014-06-17 14:24:43.585 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=560 /consoleinstance=_3992_955 "/ini=nul" "/log=winscp.log" "/command" "open ftp://EXittXann:xxx@ftparch.giove.esa.int/dsf/fr/ -rawsettings FtpUseMlsd=1" "ls"
. 2014-06-17 14:24:43.585 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: - [List all: A]
> 2014-06-17 14:24:47.837 Script: stat /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-17 14:24:47.838 Listing file "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz".
. 2014-06-17 14:24:47.838 Retrieving directory listing...
> 2014-06-17 14:24:47.838 CWD /dsf/fr/y2014/m03/d15/h13/OSP/
< 2014-06-17 14:24:47.928 250 CWD command successful
> 2014-06-17 14:24:47.928 PWD
< 2014-06-17 14:24:47.948 257 "/dsf/fr/y2014/m03/d15/h13/OSP" is the current directory
> 2014-06-17 14:24:47.949 TYPE A
< 2014-06-17 14:24:47.969 200 Type set to A
> 2014-06-17 14:24:47.969 PASV
< 2014-06-17 14:24:47.989 227 Entering Passive Mode (195,169,140,174,212,100)
> 2014-06-17 14:24:47.989 LIST -a
< 2014-06-17 14:24:48.033 150 Opening ASCII mode data connection for file list
. 2014-06-17 14:24:48.047 drwxr-xr-x   2 root     root           45 Mar 17 14:00 .
. 2014-06-17 14:24:48.047 drwxrwxr-x   6 root     root          189 Apr  3 15:06 ..
. 2014-06-17 14:24:48.047 -rw-r--r--   1 root     root         5595 Mar 17 14:00 OSPRIONO999914074NASEDF000.xml.gz
. 2014-06-17 14:24:48.047 -rw-r--r--   1 root     root         4139 Mar 17 14:00 OSPRIONO999914074NCONFG000.xml.gz
. 2014-06-17 14:24:48.047 -rw-r--r--   1 root     root         5043 Mar 17 14:00 OSPROSRT999914074NSSISA000.xml.gz
. 2014-06-17 14:24:48.047 -rw-r--r--   1 root     root         6204 Mar 17 14:00 OSPROSRT999914074NVSISA000.xml.gz
< 2014-06-17 14:24:48.257 226 Transfer complete
. 2014-06-17 14:24:48.257 Directory listing successful
. 2014-06-17 14:24:48.257 OSPRIONO999914074NIDFSS000.xml.gz;-;2578;2014-03-17T13:00:00.000Z;"root" [0];"root" [0];rw-r--r--;0
< 2014-06-17 14:24:48.257 Script: -rw-r--r--   0 root     root          2578 Mar 17 14:00 OSPRIONO999914074NIDFSS000.xml.gz
> 2014-06-17 14:24:51.725 Script: get /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-17 14:24:51.725 Listing file "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz".
. 2014-06-17 14:24:51.725 OSPRIONO999914074NIDFSS000.xml.gz;-;2578;2014-03-17T13:00:00.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2014-06-17 14:24:51.725 File: '/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz' [2014-03-17T13:00:00.000Z] [2578]
. 2014-06-17 14:24:51.726 Copying "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz" to local directory started.
. 2014-06-17 14:24:51.726 Binary transfer mode selected.
. 2014-06-17 14:24:51.726 Starting download of /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-17 14:24:51.726 Asking user:
. 2014-06-17 14:24:51.726 **Overwrite local file 'OSPRIONO999914074NIDFSS000.xml.gz'?**
. 2014-06-17 14:24:51.726 Destination directory already contains file 'OSPRIONO999914074NIDFSS000.xml.gz'.
. 2014-06-17 14:24:51.726 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
. 2014-06-17 14:24:51.726 New:         2,578 bytes, 3/17/2014 2:00 PM
. 2014-06-17 14:24:51.726 Existing:    2,578 bytes, 3/17/2014 2:00:00 PM ()
< 2014-06-17 14:24:51.726 Script: Overwrite local file 'OSPRIONO999914074NIDFSS000.xml.gz'?
< 2014-06-17 14:24:51.726 Destination directory already contains file 'OSPRIONO999914074NIDFSS000.xml.gz'.
< 2014-06-17 14:24:51.726 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
< 2014-06-17 14:24:51.726 New:       2,578 bytes, 3/17/2014 2:00 PM
< 2014-06-17 14:24:51.726 Existing:  2,578 bytes, 3/17/2014 2:00:00 PM
> 2014-06-17 14:25:02.829 TYPE I
< 2014-06-17 14:25:02.849 200 Type set to I
> 2014-06-17 14:25:02.849 PASV
< 2014-06-17 14:25:02.869 227 Entering Passive Mode (195,169,140,174,211,61)
> 2014-06-17 14:25:02.869 RETR OSPRIONO999914074NIDFSS000.xml.gz
< 2014-06-17 14:25:02.917 150 Opening BINARY mode data connection for OSPRIONO999914074NIDFSS000.xml.gz (2578 bytes)
< 2014-06-17 14:25:03.139 226 Transfer complete
. 2014-06-17 14:25:03.139 Download successful
> 2014-06-17 14:25:08.078 Script: exit
. 2014-06-17 14:25:08.078 Script: Exit code: 0
. 2014-06-17 14:25:08.080 Disconnected from server
Second without calling stat before get
. 2014-06-17 14:27:31.202 WinSCP Version 5.6 (Dev Build 4425 2014-06-10) - Do NOT distribute (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2014-06-17 14:27:31.203 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=560 /consoleinstance=_3992_955 "/ini=nul" "/log=winscp.log" "/command" "open ftp://EXittXann:xxx@ftparch.giove.esa.int/dsf/fr/ -rawsettings FtpUseMlsd=1" "ls"
. 2014-06-17 14:27:31.203 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: - [List all: A]
> 2014-06-17 14:27:35.229 Script: get /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-17 14:27:35.229 Listing file "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz".
. 2014-06-17 14:27:35.229 Retrieving directory listing...
> 2014-06-17 14:27:35.229 CWD /dsf/fr/y2014/m03/d15/h13/OSP/
< 2014-06-17 14:27:35.248 250 CWD command successful
> 2014-06-17 14:27:35.248 PWD
< 2014-06-17 14:27:35.268 257 "/dsf/fr/y2014/m03/d15/h13/OSP" is the current directory
> 2014-06-17 14:27:35.268 TYPE A
< 2014-06-17 14:27:35.288 200 Type set to A
> 2014-06-17 14:27:35.289 PASV
< 2014-06-17 14:27:35.308 227 Entering Passive Mode (195,169,140,174,142,5)
> 2014-06-17 14:27:35.308 LIST -a
< 2014-06-17 14:27:35.350 150 Opening ASCII mode data connection for file list
< 2014-06-17 14:27:35.567 226 Transfer complete
. 2014-06-17 14:27:35.601 drwxr-xr-x   2 root     root           45 Mar 17 14:00 .
. 2014-06-17 14:27:35.601 drwxrwxr-x   6 root     root          189 Apr  3 15:06 ..
. 2014-06-17 14:27:35.601 -rw-r--r--   1 root     root         5595 Mar 17 14:00 OSPRIONO999914074NASEDF000.xml.gz
. 2014-06-17 14:27:35.601 -rw-r--r--   1 root     root         4139 Mar 17 14:00 OSPRIONO999914074NCONFG000.xml.gz
. 2014-06-17 14:27:35.601 -rw-r--r--   1 root     root         5043 Mar 17 14:00 OSPROSRT999914074NSSISA000.xml.gz
. 2014-06-17 14:27:35.601 -rw-r--r--   1 root     root         6204 Mar 17 14:00 OSPROSRT999914074NVSISA000.xml.gz
. 2014-06-17 14:27:35.601 Directory listing successful
. 2014-06-17 14:27:35.601 OSPRIONO999914074NIDFSS000.xml.gz;-;2578;2014-03-17T13:00:00.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2014-06-17 14:27:35.602 File: '/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz' [2014-03-17T13:00:00.000Z] [2578]
. 2014-06-17 14:27:35.602 Copying "/dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz" to local directory started.
. 2014-06-17 14:27:35.602 Binary transfer mode selected.
. 2014-06-17 14:27:35.602 Starting download of /dsf/fr/y2014/m03/d15/h13/OSP/OSPRIONO999914074NIDFSS000.xml.gz
. 2014-06-17 14:27:35.602 Asking user:
. 2014-06-17 14:27:35.602 **Overwrite local file 'OSPRIONO999914074NIDFSS000.xml.gz'?**
. 2014-06-17 14:27:35.602 Destination directory already contains file 'OSPRIONO999914074NIDFSS000.xml.gz'.
. 2014-06-17 14:27:35.602 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
. 2014-06-17 14:27:35.602 New:         2,578 bytes, 3/17/2014 2:00 PM
. 2014-06-17 14:27:35.602 Existing:    2,578 bytes, 3/17/2014 2:00:00 PM ()
< 2014-06-17 14:27:35.602 Script: Overwrite local file 'OSPRIONO999914074NIDFSS000.xml.gz'?
< 2014-06-17 14:27:35.602 Destination directory already contains file 'OSPRIONO999914074NIDFSS000.xml.gz'.
< 2014-06-17 14:27:35.602 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
< 2014-06-17 14:27:35.603
< 2014-06-17 14:27:35.603 New:       2,578 bytes, 3/17/2014 2:00 PM
< 2014-06-17 14:27:35.603 Existing:  2,578 bytes, 3/17/2014 2:00:00 PM
> 2014-06-17 14:27:37.255 TYPE I
< 2014-06-17 14:27:37.274 200 Type set to I
> 2014-06-17 14:27:37.274 PASV
< 2014-06-17 14:27:37.294 227 Entering Passive Mode (195,169,140,174,234,252)
> 2014-06-17 14:27:37.295 RETR OSPRIONO999914074NIDFSS000.xml.gz
< 2014-06-17 14:27:37.340 150 Opening BINARY mode data connection for OSPRIONO999914074NIDFSS000.xml.gz (2578 bytes)
< 2014-06-17 14:27:37.562 226 Transfer complete
. 2014-06-17 14:27:37.562 Download successful
> 2014-06-17 14:27:42.765 Script: exit
. 2014-06-17 14:27:42.766 Script: Exit code: 0
. 2014-06-17 14:27:42.767 Disconnected from server
Thanks for your feedback!
eldnumh
Today I tested this with the current version of WinSCP 5.7 again. Unfortunately it runs differently as with the WinSCP Version 5.6 (Dev Build 4425 2014-06-10).
. 2015-03-10 15:26:04.962 --------------------------------------------------------------------------
. 2015-03-10 15:26:04.962 WinSCP Version 5.7 (Build 5125) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2015-03-10 15:26:04.962 Configuration: nul
. 2015-03-10 15:26:04.962 Log level: Normal
. 2015-03-10 15:26:04.962 Local account: umf-adm1-PC\UMF-Admin1
. 2015-03-10 15:26:04.962 Working directory: C:\UMF\UMFBase\MMI\Sessions\20150690004\Downloads
. 2015-03-10 15:26:04.962 Process ID: 2740
. 2015-03-10 15:26:04.962 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=570 /consoleinstance=_2196_591 "/log=winscp.log" "/ini=nul" "/command" "open ftp://EXittXann:xxx@ftparch.giove.esa.int/dsf/fr/ -rawsettings FtpUseMlsd=1" "ls"
. 2015-03-10 15:26:04.962 Time zone: Current: GMT+1, Standard: GMT+1 (W. Europe Standard Time), DST: GMT+2 (W. Europe Daylight Time), DST Start: 29.03.2015, DST End: 25.10.2015
. 2015-03-10 15:26:04.962 Login time: Dienstag, 10. März 2015 15:26:04
> 2015-03-10 15:26:05.159 SYST
< 2015-03-10 15:26:05.199 215 UNIX Type: L8
> 2015-03-10 15:26:05.199 FEAT
< 2015-03-10 15:26:05.237 211-Features:
< 2015-03-10 15:26:05.237  MDTM
< 2015-03-10 15:26:05.247  MFMT
< 2015-03-10 15:26:05.247  TVFS
< 2015-03-10 15:26:05.247  MFF modify;UNIX.group;UNIX.mode;
< 2015-03-10 15:26:05.247  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2015-03-10 15:26:05.247  REST STREAM
< 2015-03-10 15:26:05.247  SIZE
< 2015-03-10 15:26:05.247 211 End
. 2015-03-10 15:26:05.247 Connected
> 2015-03-10 15:26:11.232 Script: get /dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz Orbit\39d8_OSPROSRT999914268IRESOB000.sp3.gz
. 2015-03-10 15:26:11.232 Listing file "/dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz".
. 2015-03-10 15:26:11.232 Retrieving file information...
> 2015-03-10 15:26:11.232 PWD
< 2015-03-10 15:26:11.270 257 "/dsf/fr/y2014/m09/d21/OVF" is the current directory
> 2015-03-10 15:26:11.270 CWD /dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz
< 2015-03-10 15:26:11.311 550 /dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz: No such file or directory
> 2015-03-10 15:26:11.311 SIZE /dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz
< 2015-03-10 15:26:11.349 550 SIZE not allowed in ASCII mode
. 2015-03-10 15:26:11.349 Could not retrieve file information
< 2015-03-10 15:26:11.350 Script: Can't get attributes of file '/dsf/fr/y2014/m09/d25/h08/OSP/OSPROSRT999914268IRESOB000.sp3.gz'.
< 2015-03-10 15:26:11.350 Script: Could not retrieve file information
< 2015-03-10 15:26:11.350 SIZE not allowed in ASCII mode
. 2015-03-10 15:26:11.350 Script: Failed
> 2015-03-10 15:26:11.350 Script: pwd
< 2015-03-10 15:26:11.350 Script: /dsf/fr
Instead of the CWD on the folder, it does it with the file now. This returns with an 550 response, but the file definitely exists. Afterwards it does a SIZE, which was not called with the Dev Build. After this second 550 response, WinSCP seems to stop downloading. It this the intended behaviour?
Regards Heiko
This issue is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=1292
I'm sending you an email with a development version of WinSCP to address you have used to register on this forum.
