Topic "SynchronizeDirectories - track changes"
creieru
I'm using SynchronizeDirectories method and I'm interested in a way to detect if the local file already exists before start downloading it (I need to send notifications if syncronize method tries to download an existing file)
Thanks.
You cannot detect with with Session.SynchronizeDirectories.
But if it's just about a single file, you can make use of this example that basically synchronizes a file manually:
http://winscp.net/eng/docs/library_session_getfiles#example
creieru
Thanks Martin for reply...and no, it's not only one file.
But I figured out a solution by using [FileTransferred] event, and check [CreationTime] property of the file transferred.
It seems that it will to the trick.
