Topic "Trying to set username variable in batch script"
njleach
So my server requires the username in the format: www.domain.com/email@address.com
This seems to cause problems when I attempt to put it all on the one line:
open sftp://www.domain.com/email@address.com:Password@www.domain.com
So I found another forum post where it is mentioned to use a variable for the username, by adding this line to the script:
set /P USERNAME="www.domain.com/email@address.com"
and then using %USERNAME% for the open script:
open sftp://%USERNAME%:Password@www.domain.com
When I try to run this it returns 'unknown command 'set'.'
My batch file is just simple:
WinSCP.exe /console /script=script.txt
and contents of script.txt:
option batch on
option transfer binary
put test2.txt /
Any help appreciated!
The set command should be in a wrapping batch file, not in WinSCP script.
But it won't help you anyway. It makes no difference if you specify the username directly or via environment variable.
Solution is to URL-encode the slash and at sign:
open sftp://www.domain.com%2Femail%40address.com:Password@www.domain.com
See http://winscp.net/eng/docs/session_url
njleach
Thank you so much prikryl - URL-encoding the slash and @ symbol worked like a treat. Greatly appreciated! Very Happy
Nick
