Topic "Uploading File to SFTP using Key Authentication in SSIS"
Ravindra Chate
I want to upload file to SFTP using private key authentication. So i wrote below code in SSIS Script Task. Can you please suggest this much code is enough for the same or am i missing anything ?. Thanks in advance for your valuable answers.
Protocol = Protocol.Sftp,
HostName = sftpHostName, //Destination server to which we need to connect to
UserName = sftpUserId, //Destination server UserId (or Source server user id?)
SshHostKeyFingerprint = sftpHosyKeyFingerPrint,
SshPrivateKeyPath = sftpPrivateKeyPath //Entire physical path that maps to .ppk private key (Eg: C:\PrivateKey\SFTPKey.ppk)
//Start Session
session.ExecutablePath = executablePath;
session.Open(sessionOptions);
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
transferResult = session.PutFiles(fileToUpload, sftpDestinationServerPath, false, transferOptions);
// Throw on any error
transferResult.Check();
Also put query on the WinSCP site forum and put the below code [2] in there to check if this code will be good enough for authentication and file transfer using private-public key? Or else additional coding is required for key authentication.
Your code looks good. Is there any problem?
