Topic "winscp "find files" menu option not working wit []"
stanleyhokietpen
Dear support,
I am using winscp version 5.5.2 ( build 4214)
When the filename contains the square brackets [] for example filename=TTSR73_ISO.201406050358171869_InPots[4207] , winscp can not find the file when you use the "find files" (ALT+F7) menu option.
BR,
Stanley
It's because the [...] pattern has a special meaning in file mask. You need to escape it to TTSR73_ISO.201406050358171869_InPots[[]4207].
See http://winscp.net/eng/docs/file_mask#basic_syntax
