Topic "How to ignore SessionRemoteException"
I have a script in powershell to synchronize to server but i receive this error :
WinSCP.SessionRemoteException: Error listing directory '/System Volume Information'. ---> WinSCP.SessionRemoteException: Permission denied.
Error code: 3
Error message from server: Permission denied
   --- End of inner exception stack trace ---
Is it possible to ignore this type of error and continue to other directory ?
Thanks Regards
Stephane
Stephane Tinseau
I have successfully ignore this folder with adding the folder name in FileMask options parameter.
$transferOptions.FileMask = "|*.log; *.7z; *.zip; *.ric; *.pag; */System Volume Information/; */`$RECYCLE.BIN/"
But the issue still present with this other error
(f);WinSCP.SessionRemoteException: Terminated by user. ---> WinSCP.SessionRemoteException: Error listing directory '/dir1/dir2/file1'.
Error deleting file '/dir1/dir2/file1'.
I think it's again a permission issue but i can't manage all of them.
So the first question is still available:
How to catch these error without stop the copy.
Regards
Stephane
There's no way to ignore "all errors".
Stephane Tinseau
Ok,
But in this case, how to ignore the delete error ?
Regards
Stephane
I'm not sure about a cause of the error. Please attach a full session log file showing the problem (using the latest version of WinSCP).
