Topic "Upload consistently fails after 1 second"
peter.gilchrist@gmail.com
Having a heck of a time uploading to a server.
The upload fails after about 1 seconds and only makes about 364KiB of the upload leaving a small stub of a .part file.
I have attached the logs.
I am simply uploading 1 file at a time which is about 90MB
The dialog box shows 1%; then hangs; then says application not responding and often about 60 seconds later it says Host is not communicating for more than 60 seconds...
No trouble with Putty connections.
Using Windows 7 Professional
Using Transfer protocol SFTP
On Version 5.5.4
log june.txt (8.61 KB) [Download]
Description: Log
Can anyone suggest next steps for diagnosis or what additional information I could provide to get some insight? Can't figure out if this is a Linux config or a network issue or some setting in winscp or ftp clients i am missing?
On Version 5.5.4
Shocked
Did you try any other SFTP client?
Try disabling Optimize connection buffer size:
http://winscp.net/eng/docs/ui_login_connection
Hi thanks for the response.
Yes, using other SFTP Clients has the same behaviour as WINSCP.
Yes, tried enabling/disabling the connection buffer flag which had no discernible impact.
Quite perplexed ...it must be a server config?
