Topic "Scripting - where to start, part II"
cag8f
This is a continuation of a previous post of mine. I'm getting started with scripting in WinSCP. I'd like to execute a simple script that prints 'hello world' as an output. I now understand how to open winscp.com and run simple commands. I'd like to run a simple script now:
echo hello world
Winscpt documentation indicates that, to run a script, I need to enter:
winscp.com /script=example.txt
But where do I enter this? If I enter this at the winscp.com prompt, I am met with an error:
unknown command 'winscp.com'.
I encounter the same error if I first open a session, then enter that command.
Thanks in advance.
If you run winscp.com (without arguments), you start interactive scripting mode, where you can type/test commands directly, e.g. you can type your echo hello world.
If you want to test script, you save the echo hello world command to e.g. script.txt and execute it with winscp.com /script=script.txt (e.g. from Windows command line, Windows batch file or Windows shortcut).
Again see http://winscp.net/eng/docs/scripting#using_scripting
cag8f
OK thanks, this is the information I was missing.
