Topic "Silent install / uninstall"
Mr.T
The silent install does not work with the path-entry in the .INF-file I created. It installs in the default directory:-(( What do I wrong?
And is there any possibility for a complete silent UNinstall?
Mr.T
I do not know, I have never tried silent install with Inno Setup. Can you post your INF file?
Mr.T
Hi!
...here it is:
[Setup]
Lang=de
Dir=C:\Prg\WinSCP3
Group=WinSCP3
NoIcons=1
Components=main,shellext,pageant,puttygen,transl,transl\eng,transl\de
Mr.T
I have tried the script (/SILENT /LOADINF="winscp365.inf") and WinSCP was installed in C:\Prg\WinSCP3. With what version of WinSCP do you have the problem? Have you tried the latest one? How do you run the install program?
You may also try to enable logging (/LOG) and check the log file in case it shows something useful.
