Topic "Deleting file after transfer..."
chris0101
So i've read this : http://winscp.net/eng/docs/faq_delete_synchronized_files
But i'm still a little confused on how to actually get it to work..
Basically i have files synced from a remote folder to local, thats all working fine, i can't quite figure out how to get winscp to delete the file on the remote server once its transferred to my local...
I think i need the " put "command but not sure how i can do that ?
You need get -delete command, as described in "Moving Files" section of the article you refer to.
