Topic "Override dialog behaves incorrect"
fjb
Winscp Version 3.6.1. build 221
When I copy a file from remote to a local directory an the file is already in the local directory I get a dialog box. When I press copy then a new dialog box pop ups an ask to overide the file.
If I close the dialog box with pressing on the x button in the title of the window the File in the local directory is overwritten. I think this is a wrong behauviour.
The Answer of the dialog box should be count as cancel.
What protocol, SCP or SFTP? If SFTP do you have transfer resume enabled for the particular transfer?
I tested it with both protocols and the failure was reproducible with scp and sftp independent if resume was enable or disabled
I have probably fixed it. The fixed version will be released within few hours. Please test it and let me know.
