Topic "Session.GetFiles deleting folder on remote side"
abhishek741
Dear Team,
I am facing issue while using 'Session.GetFiles' which is deleting Folder on remote location when i try to get files from remote. How to resolve this. please do let me know.
Regards
Abhishek
Please show your code and attach a full session log file showing the problem (using the latest version of WinSCP).
