Topic "Automation with MDT"
Mhermsen21
I have automated the installation of WinSCP through MDT, and I'm trying to configure a site. I have exported the registry settings and they are being imported after WinSCP is installed. Everything works great, except the password does not save in site manager. Is there a way to have this save, so we do not have to enter manually? Thanks!
You can definitely create a registry entry for a password.
But you have not described what are you doing specifically to create it, so we cannot help you.
See also http://winscp.net/eng/docs/custom_distribution#distributing_passwords
Mhermsen21
I set the FTP site up and exported the registry settings. I have an MDT script that calls the registry setting to import it. It works great, except without the password. Thanks.
That should work. Does the export include Password value?
Mhermsen21
It does not include an entry for "password"
Well, that's why. I suppose you did not select Save password on Save Session as Site Dialog:
http://winscp.net/eng/docs/ui_login_save
Mhermsen21
I thought I had saved it, but I must have been mistaken. I setup the site again with saving the password and I exported and it seems to be working now. Thanks for your help.
