Topic "Missing directory names on remote node"
mj
I am using WinSCP v5.5.4 on Windows 8.1 (and Windows 7). I'm connecting to an Amazon Machine Image (AMI) via SCP, but the remote-side panel is not displaying the directories for the remote system correctly. The directory names are missing altogether (although there _is_ a generic icon), and I can't traverse them.
However, the phenomenon only occurs for a single user account on the AMI (which is running Ubuntu 14.04, and Bash). Any ideas regarding what the issue could be with the user account that is not working correctly?
Anyway, why are you using SCP? Did you consider/try SFTP?
mj
Hi, and thanks for your reply!
I have attached a log of me opening WinSCP, double-clicking on the last "directory" icon on the remote side (nothing happens); and then I close WinSCP. I have also attached a snapshot of WinSCP's remote view for your reference.
As to why I chose SCP over SFTP? Stupidity? I looked at the documentation on the WinSCP site, and the matric comparing the three different protocols and I thought SCP may be the way to go.
As it turns out, if I use SFTP, WinSCP displays my remote connection correctly and I don't have any problems.
Note that I am using a leveraged bash environment for the moment on the remote node and there are some irrevalent entries in the files for this system. If that affects WinSCP, feel free to disregard this ticket. I will clean up my environment and if I still see an issue I can re-post at that time.
Thanks again for the assistance.
mj@88.232.173.86.log (19.97 KB) Private file
Description: (none)
Description: (none)
That's it. See
http://winscp.net/eng/docs/requirements#remote_environment
mj
Confirmed. I cleaned up my env and SCP is working fine now. Sorry for the false report; and thanks for the assistance!
