Topic "Connecting to SFTP server , connection refused issue"
I am trying to an SFTP server all was working, until I put the winscp assembly on and registered it, however I can connect from our dev box both using winscp and through assembly script. But not through either from our production box, it seems like it has an incorrect password or something as it is not prompting for password. I am using the same account for both
