Topic "Powershell Filemask not working Synchronize directories"
smartel
Good day All!
I am trying to synchronize directories, including only files starting with Backup_ , with a powershell script, but it seems to ignore my filemask, here it is, any help welcome!:
[Reflection.Assembly]::LoadFrom("\\d:\temp\WinSCPnet.dll") | Out-Null
# Main script
try
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "sftpserver"
$sessionOptions.PortNumber = "222"
$sessionOptions.UserName = "ftpusername"
$sessionOptions.Password = "pwd"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
try
# Connect
$transferoptions= New-Object WinSCP.TransferOptions
$TransferOptions.FileMask = "Backup_*.zip|*/"
# Synchronize files
$synchronizationResult = $session.SynchronizeDirectories(
[WinSCP.SynchronizationMode]::Remote, "d:\temp", "/", $True, $transferoptions)
# Throw on any error
$synchronizationResult.Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
smartel
Here is the log file,
Thanks!
winscp.log (31.25 KB) Private file
Description: (none)
You are passing $transferoptions to mirror parameter of Session.SynchronizeDirectories method, not to the correct options parameter. See syntax at:
http://winscp.net/eng/docs/library_session_synchronizedirectories
smartel
Thanks!
Makes sense, here is what I use if others can use it, the 1 in there is to use the time option for criteria, did not find a nicer way to pass it on!, but it works !:
[WinSCP.SynchronizationMode]::Remote, "d:\temp", "/", $True, $False, 1, $TransferOptions)
Use [WinSCP.SynchronizationCriteria]::Time, the same syntax you are using for SynchronizationMode and Protocol already.
See http://winscp.net/eng/docs/library_powershell#enums
