Topic "Winscp 5.5.4"
LoganGuy
When I download Linux tar files to windows 7 they have a filesize the same as the linux tar but the tar is empty. This was not happening before and I have not changed Winscp. I can extract the tar in linux without a problem. What setting do I need to change? The tar file is created by drush archive-dump. BTW, the tar file is about 29MB.
regards
LoganGuy
I attached the log file.
WinSCP.log (991.94 KB) [Download]
Description: (none)
I do not see anything wrong in the log. Did you try to compare checksum of local and remote file?
LoganGuy
I"m sorry, but I do not know how to view the checksum?
On *nix, use md5sum <filename> in terminal.
On Windows, you can get a Windows equivalent command for example from:
http://www.pc-tools.net/win32/md5sums/
Anyway, any chance for me to get a test account on your server so I can try myself?
