Topic "error 141 can't open log file"
mreinsmith
I run a batch file with the following command
C:\Progra~2\WinSCP\winscp.exe /console /script=transfer.txt /xmllog=transfer.log /nointeractiveinput
it runs the script 'transfer.txt' as shown here
option batch on
option transfer ascii
open sftp://root:password1@server1 -hostkey=*
lcd V:\test
cd /remote1
mput *.xml
cd /remote2
mput *.xml
open sftp://root:password2@server2 -hostkey=*
cd /remote1
mput *.xml
cd /remote2
mput *.xml
open sftp://root:password3@server3 -hostkey=*
cd /remote1
mput *.xml
cd /remote2
mput *.xml
open sftp://root:password4@server4 -hostkey=*
cd /remote1
mput *.xml
cd /remote2
mput *.xml
it correctly logs the result for "server1" but after it connects to server2 i get the error "141 can't open log file 'transfer.log'
the log then is written to V:\test (the local directory shown above) and server2 logs correctly to that copy.
from there, SERVER3 and SERVER4 don't get logged anywhere
any ideas how to correct this behaivor?
Thank You
M
I cannot reproduce your problem with any version of WinSCP. What version are you using?
Anyway, it's not a good idea to log all sessions into one file (one would overwrite the other). Consider using some session-specific pattern in the log path. E.g. !S:
C:\Progra~2\WinSCP\winscp.exe /console /script=transfer_!S.txt /xmllog=transfer.log /nointeractiveinput
See http://winscp.net/eng/docs/ui_pref_logging#session_log
mreinsmith
I used the following to activate the script
C:\Progra~2\WinSCP\winscp.exe /console /script=transfer.txt /xmllog=%USERPROFILE%\Desktop\transfer_!S.log /nointeractiveinput
it creates 4 separate logs, but at least I can easily verify the results
Thanks for your help
M
