Topic "Include/Exclude specific File using synchronize with -filema"
solicom
is it possible to Include or Exclude some specific Files before using synchronize with -filemask ??
EX:
I want to exclude some specific files before getting synchronized to avoid them to be uploaded, for this example if exist BFFXA018.exe or CFFXA016.exe, they shouldnt be synchronized even the filemask is set for *.exe
CODE:
option echo on
option batch on
option exclude "BFFXA018.exe;CFFXA016.exe; /*"
# Connect to FTP
# Synchronize DIAGS
synchronize local -filemask="*.exe>1D|archive/" D:\fsdash\diags\SYNCdev\bin\temp\SYNC /diags/SYNC
THX
The option exclude is deprecated and replaced by -filemask.
You can combine both exclude and include mask in -filemask:
http://winscp.net/eng/docs/file_mask#include_exclude
Actually you are doing it already, so I do not see a point of the question.
Use -filemask="*.exe>1D|archive/;BFFXA018.exe;CFFXA016.exe"
