Topic "Abort session after 60 seconds"
I use winSCP script to run something on target.
After 15 seconds I get the line "Host is not communicating for more than 15 seconds." the Abort starts counting from 60 to 0 and exit.
I am looking for a way to make timeout much longer or completely disable timing.
I tried many options based on inputs from the site but sill without success. th efinal script I used (still doesnt work is below)
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
(A)bort (0 s): Abort
Terminated by user.
Windwos command
The command I use is ( I tried many options based on info from this site)" /script=script.tmp /timeout=360 /nointeractiveinput
The script I use ( I tried many options based on info from this site)
option batch off
option transfer binary
open scp://abc:abc123@ -rawsettings SendBuf=0 PingType=0
option batch off
call ./createAll
Use open scp://abc:abc123@ -timeout=360.
