Topic "Timeout waiting for external console to complete the command"
grvdutt
I'm getting following error while running from the batch script.
Timeout waiting for external console to complete the command. External console output is redirected to a pipe. Make sure the pipe is being read from.
Following is the batch script:
@ECHO OFF
mode 80,5000
title IndusInd file transfer utility
echo File tranfer utility IndusInd bank -version 1.0 -Gaurav Dutt
color 79
:loop
echo Copying...
echo echo off
echo option batch abort > ftp_uat.tmp
echo option confirm off >> ftp_uat.tmp
echo open orauat -rawsettings SendBuf=0 >> ftp_uat.tmp
echo call sh /apps_Prod/compare.sh >> ftp_uat.tmp
rem echo cd /orahome/db/PROD/db/tech_st/11.1.0/appsutil/outbound/CLONE_oraerptest >> ftp_uat.tmp
rem echo lcd C:\ERPIConfig\CSS\SOAPSender_mid >> ftp_uat.tmp
echo echo on >> ftp_uat.tmp
echo get -transfer=binary -preservetime -resumesupport=on -delete /home/orauat/utility/test/*.* C:\ERPIConfig\CSS\SOAPSender_mid\ >> ftp_uat.tmp
echo echo removing files.... >> ftp_uat.tmp
echo rm /orahome/db/PROD/db/tech_st/11.1.0/appsutil/outbound/CLONE_oraerptest/* >> ftp_uat.tmp
echo exit >> ftp_uat.tmp
"C:\Program Files\WinSCP\WinSCP.com" /script=ftp_uat.tmp
ping -n 10 127.0.0.1 > nul
DEL ftp_uat.tmp
goto loop
Is it?
Did you read this?
http://winscp.net/eng/docs/message_timeout_external_console
grvdutt
Yes sir, I already read the note, but I'm not invoking it from any program other than batch script
"Most commonly this happens when winscp.com has redirected output to a stream with limited buffer. If the stream is not being read from, the buffer gets eventually filled and winscp.com hangs, when trying to write into it. "
How can we increase the buffer?? Is there any way to resolve this.
Regards,
Gaurav
WinSCP may inherit the redirection from the batch file. How do you run the batch file?
Well that depends where and how (and if at all) you have the output redirected. But generally increasing the buffer size is not a solution. Solution is making sure the output is consumed continuously.
zbl
hi,
tagging onto this thread.
i also have the same problem.
scenario. i'm using a batch script to execute winscp.com
SET /P FILENAME=What is the name of the file to download?
ECHO File to download is: %FILENAME%
c:\"Program Files (x86)"\winscp\winscp.com /passive=on /script="c:\simple.txt" /parameter // "%FILENAME%"
c:\"Program Files (x86)"\winscp\winscp.com /script="c:\yt_simple.txt" /parameter // "%FILENAME%"
usually at the second call of the winscp.com, i will hit this problem.
with regards to the script (simple.txt, yt_simple.txt), basically, this is what happens
option echo on
open a site defined in winscp
lcd "c:/"
get -resume %1%.ts / put -resume %1%.ts
bye
The same question: How do you run the batch file?
Ntb, /passive=on specified on command-line won't get propagated to the script.
zbl
Thanks for the response.
The question as to how the script is being invoked?
I'm using windows machine. So I just open file explorer and double click on the batch file.
Thanks for your response.
