Topic "winscp.com: Network timeout error with errorlevel 0"
Ups-auch-nicht-schlecht
I execute
winscp.com /command "option batch abort" "option confirm off" "option echo on"  "open scp://root:root@radio" "bye" & echo *** Errorlevel %ERRORLEVEL%
and expected - because the host is off - an errorlevel 1. I get the network timeout error, but an errorlevel 0:
batch           abort
reconnecttime   120
confirm         off
echo            on
open scp://root***@radio-maeuse
Searching for host...
Network error: Connection to "radio-maeuse" timed out.
*** Errorlevel 0
I'm using WinSCP.com, Version 5.6.1 (Build 4547) on Windows 7 64bit
Thanks, sincerely, Guido
Your syntax is wrong. The %errorlevel% is resolved before whole line is executed. So what you are seeing is an exit code of previous command (line). In both cases.
OK, trapped again in the expansion problem, this works, thanks, G.
setlocal enabledelayedexpansion
winscp.com /command "option batch abort" "option confirm off" "option echo on"  "open scp://root:root@radio" "bye" & echo *** Errorlevel !ERRORLEVEL!
