Topic "Command Line Put with XML Files"
Grey1634
Hi Guy's,
I'm uploading an XML file to an FTP site
when transferring - the XML file is being uploaded as a temp file and once the file is fully uploaded, it is then renamed as it's proper file name
created /B20140813.csv - 226 - 15844 - 22
created /B20140813.xml.filepart - 226 - 190293 - 22
rnfr /B20140813.xml.filepart - 350 - - - 22
rnto /B20140813.xml - 250 - - - 22
quit - - 221 - - - 22
any ideas how to upload an XML file without using a temp file and then renaming..?
it does seem to do this with a csv or txt file
any help greatfully received
Disable transfer to temporary file name with put ... -resumesupport=off
See
http://winscp.net/eng/docs/ui_pref_resume
http://winscp.net/eng/docs/scriptcommand_put
Note that it's not about XML vs. TXT/CSV. Only files over 100 KB are transferred using temporary file name by default.
Grey1634
Many Thanks
all seems to be working now
